To create ridges:
In the Roof Framer dialog box, click the Ridges tab, and select Create Ridges.
Specify the ridge parameters.
Ridge Size
Specifies the ridge size in width x height, in current file units. Sizes can be edited by selecting Edit List (see Custom Frame Element Sizes).
Ridge Elevation
Specifies the ridge elevation options
Flush to Top of Rafters
Indicates that the top of the ridge should be the same as the top of the rafters
Notched into rafters, depth
Specify the depth that the ridge is notched into the rafters
Flush to Bottom of Rafters
Indicates that the bottom of the ridge should be the same height as the bottom of the plumb cut on the rafters
Specify AFF
Indicates the height of the bottom of the ridge, above the finished floor
Flush to Top of Hips
Sets the top of the ridge to be the same as the top of the hips
Class
To control appearance and visibility, select a class from the list of classes present in the drawing or create a new class (see Creating Classes)
Classes
Edits class attributes
Object Attributes
Specifies the ridge attributes
Click OK to create the ridges.
Setting Class Properties
Framing a Roof
vectorworks.net
