Saving the Scene as an Image
Vision provides a simple method of creating still images of the Scene window displaying the current lighting status. When the Scene window displays four viewports, the bottom right viewport is used to create the image. Still images are saved in  .jpg format.
To save the Scene window as a still image:
  1. Properly configure the scene and create the desired lighting look.
  2. Select Render > Render Still.
  3. The Vision dialog box opens.
  4. Specify the dimensions of the image in pixels. (The resolution of the image defaults to the dpi of the monitor.)
  5. Click the button next to the file name.
  6. The Save Rendered Image dialog box opens.
  7. Specify a file name and location, and click Save.
  8. Filename displays the set file name.
  9. Click OK to save the image.
Editing the Scene
Saving the Scene as a Video
vectorworks.net/vision
