Inserting Jumper
CablesThese break out cables connect the multicable to the devices, breaking out the power into individual circuits. Single circuit cables also go from the rack or the break out cable to the device.
Jumper cables can be automatically added to the drawing; see Creating a Jumper Cable Chain.
To insert a jumper cable:
Click the Jumper Cable tool from the Spotlight tool set.
Click a polyline drawing mode from the Tool bar. For more information on the polyline drawing modes, see Creating Polylines.
Click to place the start of the cable, and draw the cable polyline, clicking at each vertex. Double-click to finish drawing the cable.
The first time you use the tool in a file, a properties dialog box opens. Set the default properties, and click OK.
After placement, the cable path can be adjusted with the Reshape tool. The properties can be edited from the Object Info palette.
Parameter |
Description |
Cable Run ID |
Names the cable run, which is useful for labels, schedules, and other worksheets |
Rack ID |
Names the rack to which the cable connects |
Box ID |
Provides the distribution box name |
Port ID |
Names the port where the cable plugs in |
Loom ID |
Names the loom or bundle that includes the cable |
Tape Color Code |
Identifies the cable with a color code, which can be used to label racks and breaks |
Connector |
Select the type of connector |
Adapter |
Select the type of adapter, or select None if there is no adapter |
Location |
Provide a name for the jumper cable location for informational purposes |
Cable Path Length |
Displays the total length of cable required for the cable run; the label displays how much extra (unused) cable is present |
Unit Weight |
Sets the weight of the cable per unit of distance, for example, 2 kg/m |
Total Cable Weight |
Displays the weight of the entire cable |
Total Vertical Distance |
If the cable needs to travel vertically (to go around an opening, for example), the vertical distance is set for each part. This parameter displays the total vertical distance required. |
Calculate Parts |
Automatically determines the parts, or segments, of cable lengths needed to make up the cable run, using the fewest possible number of connections. The drawn cable is divided into parts, up to a total of nine parts, according to the available cable lengths in stock; each part displays with its own data. |
Stock Lengths |
Displays the available lengths of cable as set in the cable preferences |
Part __ |
Displays the length of each cable part |
Part __ Vert Dist |
Displays the vertical distance, if any, required for the part to travel around obstacles |
Part __ Loom ID |
Identifies the loom or bundle that includes this section of cable |
Cable Break __ ID |
Identifies the name of any cable break |
Include All Vertices |
When the jumper cable is drawn by the Make Jumper Cable Chain command, actual distances required may be higher than expected because the cables are not drawn in a straight line. Deselect this option to account for the jumper cables not being drawn in a straight line, providing a more realistic length estimate. |
Part Total |
Displays the total length of cable used when all the parts are added |
Part Total Is |
Displays the extra length of cable available |
Max Amperage |
Provides the maximum amperage load rating of the cable, useful for labels, schedules, and other worksheets |
Voltage |
Specifies the cable voltage provided by the power source; this value is used in the voltage drop calculation. Select Other if the provided voltage is not listed. |
Other Voltage |
When Other is selected for the Voltage, specify the power source voltage |
Wire Gauge |
Select the cable wire size |
Voltage Data |
Displays the voltage drop calculations and data. ● Voltage Drop Formula: displays the formula used to calculate the voltage drop. ● Voltage Delivered: displays the voltage delivered at the end of the cable (after accounting for the voltage drop). ● Voltage Drop: displays the amount of voltage lost to cable resistance. ● Percentage Drop: displays the percentage of voltage lost from the cable run. ● CM Value: displays the Circular Mill (CM) value assigned to the cable based on the wire gauge. |
Inventory ID |
Enter an optional inventory code for the cable |
User Field __ |
Adds optional notes or comments about the cable, useful for reporting purposes. Field 3 is for entering a number only. |
Display On Drawing |
Enables the display of cable information on the drawing
Mark Connectors |
Displays a marker and the cable length information where a cable connection is located
Lock Labels to Standard Position |
Restores text labels to their default positions, and prevents them from being moved |
Label Text Size |
Sets the text font size for the cable’s labels |
Display Length |
Displays the cable length in the label along the cable path |
Display Connector |
Displays the name of the connector type in the label along the cable path |
Horizontal Length Text |
Adjusts the cable path label to match the angle of the cable part; deselect the option to keep the text horizontal |
Display Start Label |
Adds a label at the start of the cable run; enter the text to display. The label has its own control point for adjusting its location. |
Display End Label |
Adds a label at the end of the cable run; enter the text to display. The label has its own control point for adjusting its location. |
Opens the Classes dialog box, to specify class naming for the cable labels. This allows the labels to be set to visible, grayed, or invisible. Use the suggested standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Jumper Cable Class> to place the labels in the same class as the jumper cable. ● Class Prefix: Specifies an optional default root class naming standard for the cable labels; click Use Standard Classes to begin all label class names with the prefix, so that they are sorted together. ● Use Standard Classes: Sets the class name for the label to the default suggested standard name, using the Class Prefix if there is one. ● Labels: Specifies the class name standard to use for the cable labels. |
Vertex parameters |
Edits the vertices of the path object that the cable is based upon; see Editing Vertex-Based Objects |
Selecting, Refreshing, and Converting Cables
