DesignSeries00186.pngCam Data Worksheets
Two worksheets are defined in the Cam (Imperial).sta and Cam (Metric).sta templates:
    Cam Data – lists cam data, such as rotation angle, follower displacement, velocity, and acceleration
    Cam Properties – lists the cam parameters from the Object Info palette
The worksheets are accessed by selecting them from the Window > Worksheets menu or from the Resource Manager. The Cam Properties worksheet updates when the Define Cam Profile dialog box is exited (see Defining the Cam Profile). The Cam Data worksheet updates when the cam properties are changed. The worksheets can be placed on the drawing as graphic objects, if desired (see Placing a Worksheet on the Drawing).
To prevent slower performance, when changing cam properties, keep the Cam Data worksheet closed.
Cam Design
Animating Cam Movement
Cam Diagrams
vectorworks.net
