Inserting Toilet Stalls
All Vectorworks products include toilet stalls for inserting in a drawing file. In the Vectorworks Fundamentals, Landmark, and Spotlight products, the toilet stalls are inserted from an object library through the Resource Manager. In the Vectorworks Architect product, the stalls are inserted with the Toilet Stall tool.
To insert a toilet stall in Vectorworks Architect:
  1. Click the Toilet Stall tool from the Furn/Fixtures tool set.
  2. Do one of the following:
    To use an existing plug-in object resource, click Active Def on the Tool bar. From the Resource Selector, double-click a resource to activate it. Click on the drawing or wall to place the object, and click again to set the rotation.
    To create a custom plug-in object, click on the drawing or wall to place the object, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default properties, and click OK. The properties can be edited from the Object Info palette.
Symbols Within a Wall
vectorworks.net
