Spot00012.pngNumbering Hoists
Hoists can be numbered by a variety of methods and numbering patterns.
To number existing hoists:
  1. Select the hoists to be numbered. If manually numbering hoists, no hoists need to be selected.
  2. Select Spotlight > Hoists > Number Hoists.
  3. The Number Hoists dialog box opens.
  4. Click OK.
  5. If numbering hoists manually, click on the hoists one by one, and then click in a blank area of the drawing to stop numbering. Otherwise, click to set the starting hoist.
The selected hoists are numbered as specified. The Hoist Number parameter in the Object Info palette updates to reflect the new numbering.
Placing Hoists
Selecting Hoists or Hoist Origin Objects
vectorworks.net
