DesignSeries00040.pngAdding Text to a Database
Text objects can be added from the drawing to a selected database. This is convenient for retrieving text from older, converted files for use with the Notes Manager or when adding frequently-used text to a database for easy future insertion as an annotation.
To add drawing text to a database:
  1. Select Text > Add Text to Database.
  2. The Add Text to Database dialog box opens. Specify which text objects to select and indicate in which databases to search for duplicated text.
  3. Click OK. If any of the text is not found in the text search database(s), the Notes Manager: Add Text to Database dialog box opens.
  4. The text to be added is listed on the right. As described in Placing Database Keynote Legends, the text can be added to the active database in the desired section. Click OK.
Placing Database General Notes
Reconciling Database and Drawing Notes
Notes Management with Databases
Notes Management
vectorworks.net
