To edit a skylight:
Select the skylight.
A selection handle displays at the skylight location.
Position the cursor over the selection handle for the skylight and click.
The Edit Roof Element dialog box opens, with the skylight parameters displayed.
Edit the parameters as described in Inserting a Skylight.
To remove the skylight completely, select Remove object.
Click OK.
The drawing area displays the specified changes for the selected skylight.
The skylight miter parameters can be changed from the Object Info palette.
| Skylight Miter | Description |
| Vertical | Cuts the roof vertically at both the top and bottom of the skylight
| Splayed | Cuts the roof horizontally at the top of the skylight, and vertically at the bottom
| Square Cut | Cuts the roof perpendicular to the roof at both the top and bottom of the skylight
