Server Syntax
Server commands use a common format.
Command_Name Parameter_1 Parameter_2
●    The command line contains only Latin characters, and the command name and the parameters are separated by a single space. No spaces are allowed within the command name or parameters.
●    Tab and New Line symbols cannot be used. Each command must be entered on a separate line.
●    Parameters cannot use the following characters: < > & "
●    To add a command to the option file, start the command line with a hash tag symbol (#).
●    The maximum length of a line is 1024 characters.
●    Upper case and lower case characters are not differentiated.
●    The wildcard symbol (*) is permitted.
●    Restrictions or permissions can apply to a group of similar users, computers, or IP addresses, by using the GROUP, HOST_GROUP,INTERNET_GROUP commands; however, the group must be defined before it can be used. Multiple groups can be created, and additional members can be added to an existing group at any time using the same command.
Server commands use common parameters to define client-side users.
Command
Description
Syntax
user
Specifies a user account name for setting account restrictions or permissions
USER user_name
Example: USER tom
host
Specifies a computer name for setting account restrictions or permissions
HOST host_name
Example: HOST pc10196
internet
Specifies an IP address for setting account restrictions or permissions
INTERNET IP_address
Examples:
Internet 172.67.94.13
Internet 172.16.*
group
Defines a group of multiple users
GROUP group_name name_1 name_2
Examples:
GROUP engineers tom sarah franz
GROUP engineers paul (adds paul to the existing engineers group)
GROUP architects laura_cheng juan_jimenez
host_group
Defines a group of multiple computer names
HOST_GROUP group_name pc_1 pc_2
Example: HOST_GROUP designers pc10196 pc10567
internet_group
Defines a group of multiple IP addresses
INTERNET_GROUP group_name IP_1 IP_2
Example: INTERNET_GROUP drafting 1.1.1.1 2.2.*.* 3.3.3.3
Specifying Server Options
Server Status Screen
Main Server Administration Screen
vectorworks.net
