ArchLand00017.pngStair Settings: Graphic Attributes Tab
The settings on the tab can be saved as a set and then loaded, replacing the current tab parameters.
  1. Click the Graphic Attributes tab to specify the appearance of stair components.
  2. The graphic attributes of each stair part are listed. Double-click an item to edit it.
  3. An attributes dialog box with the name of the item is displayed. See The Attributes Palette for information on setting attributes.
  4. Set the attributes and click OK to return to the Graphic Attributes tab.
Stair Settings: General Tab
Stair Settings: Geometry Tab
Stair Settings: 2D Graphics Tab
Stair Settings: Construction Tab
Stair Settings: Railings Tab
Managing Stair Styles
Saving a Stair as a Symbol
Setting Minimum and Maximum Values for Stair Geometry Parameters
Stair Properties
Transferring Stair Properties
Creating a Stair
Inserting Stairs
vectorworks.net
