Inserting Connections AutomaticallySelected structural elements can be connected automatically with hoists at likely connection points with the Insert Drop command.
To connect structural elements automatically:
Select the two structural elements to be connected.
Select Braceworks > Insert Drop.
The Insert Drop command is available for Vectorworks Spotlight software but is not present in the Spotlight workspace. It can be added to the Spotlight workspace (see Customizing Workspaces).
A hoist is inserted at possible connection points between the structural elements.
