Bevel
GearsA bevel gear set consists of a gear and pinion.
To insert a bevel gear:
Click the Bevel Gears tool from the Machine Components tool set.
The Bevel Gear tool and Bevel Gear - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
