Assigning, Creating, Editing, and Deleting Door Hardware Sets
A door hardware set can be assigned to the door, and a door operator device (such as a knob or lever) can be selected from default content to display on the 3D door.
To assign, create, edit, or delete a door hardware set:
  1. From the Hardware pane of the Door Settings dialog box, select Include Hardware and click Manage Hardware.
  2. The Door Hardware Library dialog box opens for selecting a door hardware set and door operator device.
    The Door Hardware Library.txt file is in the Vectorworks default content folder [Vectorworks]\Libraries\Defaults\Door - Hardware.
  3. Select Edit or Add.
  4. The Edit or Add Door Hardware Set dialog box opens. The Add dialog box is similar to the Edit dialog box except that all fields are blank.
  5. Complete each field with the desired information to add a new door hardware set, or edit the desired fields to change an existing door hardware set.
  6. Click OK, and then click Done to return to the Door Settings dialog box.
The applied information appears in the door hardware legend generated (see Using Preformatted Reports).
Concept: Resource Libraries
Door Settings: Hardware Pane
Creating Door Schedules or Worksheets
