Spot00087.pngReplacing Stage Decks and Trusses with Symbols
Stage deck objects and straight or curved trusses can be replaced with symbols. This improves the counts of the objects in reports and makes the representation of identical objects in the drawing consistent. In addition, after the initial stages of design, generic stage decks or trusses can be replaced with symbols that contain manufacturer-specific parameters.
Select either stage deck or truss objects. If both are selected, the Choose One Type of Object dialog box opens, and you are prompted to choose one or the other type of object.
Replacing Stage Deck Objects
To replace selected stage deck objects in the drawing with stock symbols:
  1. Select the stage deck objects to be replaced.
  2. Select Spotlight > Object Conversion > Replace with Stock Symbols.
  3. The Replace Object with Stock Symbol dialog box opens.
  4. Select each category of identical stage decks, and then choose the symbol to replace them. Click in the Action column until Replace displays. Other options in the Action column include Keep or Delete; if you clicked Replace but instead, you wish to remove or retain the original stage deck, click to change the action.
  5. Click OK.
Replacing Truss Objects
To replace selected straight or curved truss objects in the drawing with stock symbols:
  1. Select the truss objects to be replaced.
  2. Trusses that have been converted to hanging position objects can be selected. Trusses that have been rotated in 3D cannot be selected.
  3. Select Spotlight > Object Conversion > Replace with Stock Symbols.
  4. The Replace Object with Stock Symbol dialog box opens.
  5. Select each category of identical trusses, and then choose the symbol to replace them. Click in the Action column until Replace displays. Other options in the Action column include Keep or Delete; if you clicked Replace but instead, you wish to remove or retain the original truss, click to change the action.
  6. Click OK.
Inserting a Stage Deck
Inserting a Straight Truss
Inserting a Curved Truss
