All Vectorworks products include shelving units for inserting in a drawing file. In the Vectorworks Fundamentals product, the shelving units are inserted from an object library through the Resource Manager. In the Vectorworks Design Series products, the units are inserted with the Shelving Unit tool.
In addition to these common shelving units, Vectorworks offers the flexibility of Creating Custom Cabinets.
To insert a shelving unit in the Vectorworks Design Series:
Click the Shelving Unit tool from the Furn/Fixtures tool set.
From the Tool bar, click either Active Def to select an existing resource from the Resource Selector, or click Preferences and set the default parameters to create a custom object.
Click on the drawing to place the object, and click again to set the rotation. The properties can be edited from the Object Info palette.
Optionally, after placement you can create a plug-in object style, which combines style parameters (with a fixed value established by the style) and instance parameters (which can be set independently for each instance of the styled object in the drawing). See Creating Plug-in Object Styles.
