To create model views from selected valid geometry in the plot layer:
From a plot layer that contains valid Vectorworks Spotlight objects (hanging positions, trusses, lighting instruments, and non-architectural 2D or 3D geometry or hybrid symbols), select the items to be rotated in a model view.
Select Spotlight > Visualization > Create Plot and Model View.
The Create Plot and Model View dialog box opens.
Click OK.
A design layer viewport is created for the selected Vectorworks Spotlight geometry, replacing those objects on the plot layer; if Vertical is selected, the model view displays the design layer viewport in a vertical orientation. A single definition layer contains the original selected Vectorworks Spotlight geometry.
If Vertical is not selected, use the Rotate tool in the model layer to orient the design layer viewport. See Rotate Tool.
