To create model views from all valid geometry in the plot layer:
From a plot layer that contains valid Vectorworks Spotlight objects (hanging positions, trusses, lighting instruments, and non-architectural 2D or 3D geometry or hybrid symbols), ensure that no items are selected.
Select Spotlight > Visualization > Create Plot and Model View.
The Create Plot and Model View dialog box opens.
Click OK.
A design layer viewport is created for each hanging position instance and non-architectural geometry, replacing the original objects on the plot layer.
● If Separate is deselected, a single definition layer contains all Vectorworks Spotlight geometry.
● If Separate is selected, a definition layer exists for each instance of the Vectorworks Spotlight geometry.
Finally, a model layer contains design layer viewports for rotation and proper positioning.
In the model layer, use the Rotate tool to orient the design layer viewports. See Rotate Tool.
