Spot00037.pngInserting Gobo Projections
A pattern, texture, or color can be placed on a lighting instrument and projected onto the stage. This special light source and instrument combination is a gobo projection.
Lighting instruments with gobo projections cast a light beam that can be rendered. You can then preview the effect of the gobo projection textures on the stage. For more information on rendering, see Rendering the Drawing.
Gobo Texture Libraries
Creating Gobo Textures
Editing Gobo Texture Transparency Settings
Inserting a Gobo Projector
Showing Gobo Projections
