Double-Line Polygon Tool
Use the Double-Line Polygon tool to create a wide variety of open or closed polygons that have two parallel lines, a double-lined polygon with a width, or two parallel lines with a polygon fill. Double-line polygons can have as many as 32,767 vertices.
Mode
Description
Top Control Line
The cursor creates the right line
Center Control Line
Creates lines equidistant from the cursor
Bottom Control Line
The cursor creates the left line
Custom Control Line
Specify an offset value
To create a double-line polygon:
  1. Click the Double-Line Polygon tool from the Basic palette.
  2. Select the offset method.
  3. Enter the distance between the double lines in the Separation field on the Tool bar.
  4. Click the Preferences button to specify any other parameters.
  5. Click OK.
  6. Click to set the polygon’s start point (first vertex).
  7. Click at each vertex.
  8. Double-click to mark the polygon’s end point (final vertex).
Alternatively, if Create Polygons or Creates Lines and Polygons is selected in the Double Line Preferences dialog box, after completing all but the final click, press the keyboard shortcut (K by default) to automatically close the polyline. The shortcut also closes path-based objects, such as hardscapes and spaces, that function similarly to the Polyline tool. See Modifying Special Shortcuts to change the shortcut.
Applying Components Between Double Lines
2D Polygon Tool
Creating Double Lines
Regular (Equal-sided) Polygon
Displaying and Reversing Object Direction
