The Push/Pull tool is in the 3D Modeling tool set.
The Push/Pull tool interactively reshapes planar geometry, creating bosses (protrusions) or cutouts on solids by adding or subtracting volume from a solid. The volume is created or subtracted by extruding a face in Extrude Face mode, including all the geometry present on a face in Move Face mode, or extruding a planar NURBS curve (or group of closed, non-intersecting NURBS curves) in Sub-Face mode.
Three modes are available.
Mode |
Description |
Extrude Face |
Selects the planar face of a solid, a 2D planar object, or NURBS curve, to add to or subtract volume, creating perpendicular faces |
Move Face |
Extends the planar face of a solid, adding or subtracting the face along with any geometry present on the face |
Sub-Face |
Selects a curve or group of curves to add to or subtract volume from a solid |
To preserve the primitive profile geometry of an extrude, right-click on the extrude and select Edit from the context menu. See Object Editing Mode.
► Click here for a video tip about this topic (internet access required).
