ArchLand00065.pngRailing and Fence Settings
The settings are grouped into several panes of related parameters. Select each group of parameters from the list in the left pane of the dialog box; the parameters display in the center pane. The right pane of the dialog box always displays a preview of the object based on the current settings.
Railing/Fence Settings
Railing/Fence Settings: General Pane
If you select a different symbol after making parameter changes on any tab, the New Railing dialog box opens. Each railing or fence symbol has default settings. If you switch to a new symbol, you can either use the default settings, or transfer the current settings to the new object. From the dialog box, select specific settings to transfer, or click All or None to select or deselect all the settings.
Railing/Fence Settings: Top Rail Pane
Railing/Fence Settings: Post Pane
Railing/Fence Settings: Frame/Panel Pane
Railing/Fence Settings: Start/End Pane
For Top/Plan view, enter an angle for chamfers at each end of the railing or fence; enter 0 (zero) for a straight edge.
Railing/Fence Settings: Attributes Pane
The class and class graphic attributes of each part of the railing or fence display. Double-click an item to open an attributes dialog box. See The Attributes Palette for information about setting attributes.
Saving a Railing or Fence as a Symbol
You can save the railing or fence configuration as a symbol in the current file or in a library file. The object is saved as a red symbol and becomes a plug-in object with pre-set parameters when inserted. See Symbols.
To save a railing or fence as a symbol:
  1. From the Railing/Fence Settings dialog box, open the General pane, and click Save as Symbol.
  2. The Save Railing/Fence dialog box opens.
  3. Select the destination file for the symbol.
  4.     To save the symbol in a library file, select Save as template in library file and enter a name for the symbol.
        To save the symbol in the current file, select Save as symbol in current document, enter a name for the symbol, and select a folder destination for the symbol.
  5. Click OK.
    If you saved the symbol in the user default library, it is available from the Symbol Selection list in the General pane, under the Custom Defaults category. Library files can be shared among users.
    If you saved the symbol in the current file, it is available from the Symbol Selection list in the General pane, under the Current document category, and also from the Resource Manager. Symbols can be shared by exporting them from the Resource Manager (see Exporting Resources).
Creating Railings and Fences
