Viewport Properties
Once it has been created, edit the viewport in the Object Info palette, or select Properties from the viewport’s context menu to open the Properties dialog box.
A viewport is assigned to the None class when it is created, and its visibility is controlled by the class settings when that class is not active.
Properties of Section Lines and Section-Elevation Markers
Detail Callouts and Detail-Callout Markers
Detail Callout Instances
Advanced Sheet Layer Viewport Properties
Advanced Design Layer Viewport Properties
Advanced Section Viewport Properties
Creating Sheet Layer Viewports
Creating Design Layer Viewports
Creating Section Viewports
Creating Interior Elevation Viewports
Creating Detail Viewports
Modifying Viewports
Viewport Status
Updating Viewports
Concept: Layers Overview
