Creating Door Schedules|
Command |
Workspace: Path |
Create Report |
● Architect and Landmark: Tools > Reports ● Spotlight: Spotlight > Reports |
To create a door schedule:
Do one of the following:
● Select the command, and then select a pre-formatted schedule, as described in Using Preformatted Reports.
● Select the command, and then create a report for objects with a door record, as described in Creating Reports.
The worksheet is populated with information from the door objects in the current drawing.
To edit the worksheet after it has been created, see Editing Worksheets.
To place the worksheet on the drawing, see Placing a Worksheet on the Drawing.
