Adding Text to a DatabaseCommand |
Path |
Add Text to Database |
Text |
Text objects can be added from the drawing to a selected database. This is convenient for retrieving text from older, converted files for use with the Notes Manager or when adding frequently-used text to a database for easy future insertion as an annotation.
To add drawing text to a database:
Select the command.
The Add Text to Database dialog box opens. Specify which text objects to select and indicate in which databases to search for duplicated text.
Click
to show/hide the parameters.
Click OK. If any of the text is not found in the text search database(s), the Notes Manager: Add Text to Database dialog box opens; see Managing Database Notes to add text to the active database in the desired section..
