DesignSeries00033.pngProject Revision and Issue History Worksheets
The Title Block Manager creates worksheets with the information from the data records and record formats maintained by the title blocks marked for inclusion in the Title Block Manager operation.
When the issue history and revision history reports are run, the name of the worksheet resource in the drawing file is automatically incremented with a suffix: “-1” if the report is all on one page, and a series of numbers (-1, -2, -3 and so on) for each page if the Create Pages/Multiple Worksheets option is selected. The sheet revision log has the suffix of the report run date.
The default worksheets have the following names and are available in the default content (Vectorworks Libraries\Defaults\Reports_Schedules\Title Block Reports.vwx).
●        Title Block Project Issue History
●        Title Block Project Revision History
●        Sheet Revision Log
These worksheets can be customized (see Concept: Worksheet Overview) and saved into the user folder to be used for future reports.
To create an issue or revision report:
From the Worksheets section of the Title Block Manager, click on the kind of worksheet to create and set the parameters.
The worksheets are created after the Title Block Manager dialog box closes.
Concept: Using Title Block Borders
Adding a Title Block Border
Batch Publishing
