Rounded rectangles can be created with symmetrical, proportional, or unconstrained corner diameters.
Symmetrical corners have the same X and Y rounded corner diameters. Proportional corners are created as one third of the width and height of the rounded rectangle; for example, a rounded rectangle with a width of 6” and a height of 3” has a Diam X value of 2” and a Diam Y value of 1”. Rounded rectangles with both symmetrical and proportional corners have the same horizontal and vertical arc lengths. Unconstrained rounded rectangles can also be created using specific X and Y corner diameters.
Two modes are available. The Push/Pull mode is available in 3D views for instantly extruding the rectangle after creation.
Mode |
Description |
Diagonal |
Defines the dimensions of the box containing the rounded rectangle |
Rotated |
Defines the width and height lengths to create the rounded rectangle, which can be rotated if desired |
Push/Pull (3D views only) |
Instantly extrudes the rounded rectangle after creation; available in 3D views |
Preferences |
Sets the default properties of rounded rectangles |
Mode |
Tool |
Tool set |
Diagonal
Rounded Rectangle
Basic |
To create rounded rectangles by box:
Click the tool and mode.
Click Preferences.
The Round Rect Preferences dialog box opens; specify the preferences.
Click
to show/hide the parameters.
Click to set the start point.
Click to set the end point of the rectangle.
Mode |
Tool |
Tool set |
Rotated
Rounded Rectangle
Basic |
To create rounded rectangles by width and height:
Set the rounded rectangle preferences as described in Rounded Rectangle by Box.
Click to define the rounded rectangle rotation angle and width.
Click to define the rounded rectangle height.
Mode |
Tool |
Tool set |
Push/Pull
Rounded Rectangle
Basic |
To extrude a created rounded rectangle:
In a 3D view, click the tool and mode.
Create a rounded rectangle using any of the modes described in the previous sections.
With the rectangle still selected, click, move the cursor, and then click to create the extrude.
A planar rectangle can be extruded at any time with the Push/Pull tool. See Direct Modeling with the Push/Pull Tool.
The extrude height can be changed with the Reshape tool (see Reshaping Extruded Objects and Solid Primitives), or modified from the Object Info palette.
