Drawing Property Lines Manually|
Mode |
Tool |
Tool set |
Modes for the Polyline Tool |
Property Line
Site Planning |
To create property lines by drawing a polyline:
Click the tool and mode.
Click to set the starting point of the first property line segment.
For information on using the polyline creation options, see Creating Polylines.
Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the property line is complete. Return to the start point or simply double-click to finish creating the property line.
If you use non-arc vertices, the curve segments are approximated into arc segments.
If this is the first time the Property Line tool has been used, the object properties dialog box opens. Set the defaults (see Property Line Parameters).
