Command |
Path |
View bar |
Organization |
Tools |
Create and manage structural elements of the drawing using the Organization dialog box. This dialog box has specialized functions to sort and select its list items; see List Box Functionality.
To use the Organization dialog box:
Select the command or click the View bar button.
Alternatively, select Edit View from the Saved Views menu on the View bar.
The Organization dialog box opens.
Select the appropriate tab for the element to be created or edited.
From the top of the dialog box, select either Details or Visibilities view.
Generally, the Details view shows the current settings for each element, and enables editing of layer and class visibilities in the drawing area; the Visibilities view enables editing of layer and class visibilities in viewports and in saved views (see Visibility Columns).
Buttons at the bottom of each tab provide creation and management functions. Alternatively, right-click on a list item to display a context menu, which has most of the same functions as the tab buttons.
If a description is entered for the class, it displays in a screen tip when you position the cursor over the class name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
Click
to show/hide the buttons and context commands.
The design layer name displays in italics if the layer is referenced; the name is blue if the layer is checked out from a shared project. If a description is entered for the design layer, it displays in a screen tip when you position the cursor over the layer name. If the layer is referenced, the screen tip also displays the full layer name and the source file name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
Click
Stories TabIn the Vectorworks Architect product, an additional Stories tab is available; see Setting Up the Building Structure with Stories.
The sheet layer name displays in blue if the layer is checked out from a shared project. If a description is entered for the sheet layer, it displays in a screen tip when you position the cursor over the layer name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
Click
The viewport name displays in blue if it is checked out from a shared project.
Click
Click
Click
