DesignSeries00080.pngAttaching a sketch to a redline
Tool
Tool set
Redline
Dims/Notes
In screen plane mode, one or more selected objects can be attached to a redline object to illustrate the redline comments. The object to be attached as a sketch must be selected before drawing the redline; this process converts the selected object to a sketch symbol and places it in a Redline Sketches symbol folder saved with the file.
To attach a selected object as a redline sketch:
1.      Switch to the screen plane (see Planar modes of 2D objects: Screen plane and layer plane).
2.      Select the object to be converted to a sketch.
3.      Click the tool, and draw the redline as described in Placing redlines .
The Place Redline dialog box opens.
4.      Select Attach the current selection as a sketch.
5.      The selection is converted to a symbol that is attached to and moves with the redline object.
The sketch can be hidden by deselecting Show Sketch from the Object Info palette.
Error/revision management using redlines
Placing redlines
