Placing the Camera Match object
Command
Path
Place Camera Match Object
View > Camera Match
The Camera Match object contains the photo, controls, and target reference for manipulation; it is inserted into the drawing by placing it in the sheet layer viewport while in Edit Annotation mode.
To place a Camera Match object:
1.      Right-click on the sheet layer viewport and select Edit Annotations from the context menu. See Creating annotations for sheet layer viewports .
2.      Select the command.
The Camera Match Settings dialog box opens.
3.      Select a photo from the current file, or click Import New Image to import a new photo image as described in Importing image files.
4.      Select the Camera Match reference from the Reference Object list, and select the line style to use for the extension lines.
A Camera Match object is placed in the viewport annotation. The properties of the Camera Match object can be edited from the Object Info palette.
The Camera Match preview object
Camera Match
