Tapped holesMode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Hole - Tapped
Detailing |
Multiple drilled and tapped hole tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Both 2D and 3D tapped holes are available. The 3D tapped hole is a solid object that can be subtracted from any other solid object to create accurate 3D models of molds, dies, and many other machine parts (see Subtract solids).
To insert a tapped hole:
1. Click the tool and mode.
2. Click to place the object in the drawing, and click again to set the rotation.
Click
to show/hide the parameters.
