Moving objects by clicking with the Move by Points tool
Tool
Tool set
Shortcut
Move by Points
Basic
Shift+M
Objects can be moved, duplicated, and distributed along a specified distance by clicking with the Move by Points tool. This tool also moves symbols within walls (see Moving symbols in walls with the Move by Points tool).
Mode
Description
Move
Moves and duplicates selected objects according to the distance and direction specified by two mouse clicks
Distribute
Moves and distributes duplicate objects between the points specified by two mouse clicks
Reference Point
Moves selected objects according to a clicked reference point and a specified offset distance from that point; the Preferences settings are not applicable when this mode is selected
Object Retention
Keeps the original objects; this is the same as selecting the Retain option in the tool preferences
Moving objects with the Move or Distribute mode
Mode
Tool
Tool set
Shortcut
Move
Distribute
Move by Points
Basic
Shift+M
To move, duplicate, and distribute selected objects:
1.      Select the object or objects to move and/or duplicate.
2.      Click the tool, and then click Preferences.
The Move by Points Settings dialog box opens. Select the settings.
To change the selected objects, press and hold the Alt key (Windows) or Cmd key (Mac) while you Shift-click or click-drag to select the objects. The Selection tool is activated in boomerang mode while the Alt or Cmd key is pressed.
3.      Click either the Move or Distribute mode, depending on the desired outcome.
Mode
Number of duplicates
Original object retained
Result
Move or Distribute
0
not applicable
Moves the original object(s) to the location specified by clicking
Move or Distribute
1
No
Move or Distribute
1
Yes
Creates one duplicate of the original object(s), placed at the location indicated by clicking
Move
> 1
No
Moves the original object(s), placing the original at the location specified by the first click, and placing the duplicates the same distance apart from each other along the vector created by the two click points
Move
> 1
Yes
Creates duplicates of the original object(s), placing the first duplicate at the location specified by the second click, and placing additional duplicates the same distance apart from each other along the vector created by the two click points
Distribute
> 1
No
Moves the original object(s), placing the original at the location specified by the first click, and distributing the duplicates between the two click points, and along the vector created by the two points
Distribute
> 1
Yes
Creates duplicates of the original object(s), distributing the duplicates between the two click points, and along the vector created by the two points
4.      Click once (anywhere on the drawing) to indicate the vector start point, and click again to indicate the vector end point. Duplicates are placed in the vector direction, at the distance specified by the click points, along the line defined by the click points.
Moving objects with the Reference Point mode
Mode
Tool
Tool set
Shortcut
Reference Point
Move by Points
Basic
Shift+M
Reference Point mode can work two ways; the first click can either indicate the object to be moved or the reference point from which the object will be offset.
To move selected objects using a reference point:
1.      Select the objects to move.
2.      Click the tool and mode.
3.      Click to indicate either the reference point, or a point on the selected object.
The Enter Offset dialog box opens.
4.      The current Offset distance between the two click points displays. Enter the desired distance.
5.      Select whether the first click made was the reference point or a point on the object to be moved.
The selected object is moved as specified, along the line defined by the click points.
6.      The setting for how the first click is interpreted remains set until it is changed.
Moving objects
