Command |
Path |
● File > Document Settings ● Document context menu ● Quick Preferences |
Document preferences apply only to the current drawing, and they remain in effect until they are changed. When you create a template, the current document preferences are saved with the template (see Creating templates).
To change the preference settings in the document:
1. Select the command.
The Document Preferences dialog box opens.
2. Click each tab to set the document preferences for that tab.
Click the Display tab to set the display preferences.
Click
to show/hide the parameters.
Click the Dimensions tab to set the dimension preferences.
Click
Default dimension standards are presented in the following table.
Standard |
Description |
Text placement |
Marker style |
Text rotation |
Above dim. line |
Within dim. line |
Slash |
Arrow |
Aligned |
Horiz. |
Arch |
Architectural Standards |
X |
X |
X |
ASME |
American Society of Mechanical Engineers |
X |
X |
X |
BSI |
British Standards Institute |
X |
X |
X |
DIN |
German Standards |
X |
X |
X |
ISO |
International Standards Organization |
X |
X |
X |
JIS |
Japanese Industrial Standards |
X |
X |
X |
SIA |
Swiss Standards |
X |
X |
X |
ASME Dual Side By Side |
X |
X |
X |
ASME Dual Stacked |
X |
X |
X |
Click the Resolution tab to set the resolution preferences.
Click
Click the Plane Mode tab to set the plane mode preference, depending on how you prefer to work and what you are drawing. Planar tools, such as the Rectangle tool, normally can operate in either the screen plane or in the current working plane, which is usually the layer plane. With this preference setting, planar tools can be set to operate in the screen plane only, active 3D working plane only, or any available plane, depending on the option selected. This setting does not affect tools that require an active working plane, such as the NURBS Curve tool, tools like the Split tool that always operate in the screen plane, or tools that are not affected by the planar choice, such as the Eyedropper tool. See Concept: Objects in the screen plane and in the layer plane for a discussion of how planes function in the Vectorworks products.
The plane mode preference does not affect the Object Info palette planes list.
Click
Document preferences: Plan
Shadows tabIn the Vectorworks Architect and Landmark products, click the Plan Shadows tab to set the shadow style preferences for plants and massing models. These preferences apply in Top/Plan view for plants that are set to use the document preference shadow settings (available only in Vectorworks Landmark; see Plant style: Visualization pane) and for massing models set to display shadows (see Creating a massing model).
Click
