The most commonly used Vectorworks, document, and interactive preferences are available for access from buttons on the Tool bar. Other commonly used settings, such as those for the clip cube, are similarly available. The Quick Preferences menu controls which buttons display on the Tool bar. The Data Bar and Edit Group Options list and the Zoom Line Thickness, Default 3D Render Mode, and Default 3D Projection preferences are enabled by default on the Quick Preferences menu.
Select the desired item to display its shortcut button on the Tool bar, if it is not already present. A check mark to the left of an item indicates that it is selected. Buttons display in the order the item was selected, so the first selected item displays the furthest left on the Tool bar. If the application window is resized, the Tool bar will truncate the display of buttons when necessary and replace them with ellipses on the right.
Menu commands |
Description of button functionality |
Auto Display Detail Levels for Design Layers
Displays the Auto Display Detail Levels for Design Layers preference button (see Document preferences: Display tab) |
Auto Join Walls
Displays the Auto Join Walls preference button (see Vectorworks preferences: Edit tab) |
Autosave
Displays the Autosave preference button (see Vectorworks preferences: Autosave tab) |
Black and White Only
Displays the Black and White Only preference button (see Document preferences: Display tab) |
Black Background
Displays the Black Background preference button (see Vectorworks preferences: Display tab)
Displays the Data Bar and Edit Group Options list (see Data bar and edit group options) |
Display Light Objects
Sets the display of light objects (see Vectorworks preferences: Display tab). The icon indicates the currently selected option. |
Sets the preferred 3D render mode, which is applied whenever a drawing is switched from Top/Plan to a 3D view (see Vectorworks preferences: 3D tab) |
Sets the preferred 3D projection, which is applied whenever a drawing is switched from Top/Plan to a 3D view (see Vectorworks preferences: 3D tab) |
Display Viewport Out-of-date Borders
Displays the Display Viewport Out-of-date Borders preference button (see Document preferences: Display tab) |
Drop Shadows
Displays the Drop Shadows preference button (see Document preferences: Display tab) |
Duplicate Tags with Objects
Displays the Duplicate Tags with Objects preference button (see Vectorworks preferences: Edit tab) |
Project Sharing Options
Sets the highlighting style for objects that are checked out from a shared project (see Checking out and releasing objects) |
Show Acquisition Hints
Displays the Show Acquisition Hints preference button (see Vectorworks preferences: Interactive tab) |
Show Clip Cube
Displays the Show Clip Cube preference button (see Viewing a model with the clip cube) |
Show Grid
Displays the Show Grid preference button (see Grid snapping) |
Show Other Objects While in Edit Modes
Displays the Show Other Objects While in Edit Modes preference button (see Vectorworks preferences: Display tab) |
Show Page Boundary
Displays the Show Page Boundary preference button (see Page setup) |
Show Rulers
Displays the Show Rulers preference button (see Vectorworks preferences: Display tab) |
Use Layer Colors
Displays the Use Layer Colors preference button (see Document preferences: Display tab) |
Zoom Line Thickness
Displays the Zoom Line Thickness preference button (see Vectorworks preferences: Display tab) |
Document Preferences |
Opens the Document Preferences dialog box (see Setting document preferences) |
Vectorworks Preferences |
Opens the Vectorworks Preferences dialog box (see Setting Vectorworks preferences) |
