Placing a single title block border on a layer
Mode
Tool
Tool set
Single Paper Page
Title Block Border
Dims/Notes
The most common usage of a title block border is to insert a single title block border object on a layer, at full sheet size so that when plotted at 100%, the entire drawing area is surrounded by the title block border.
If you need to print a sheet on a printer that cannot print the full sheet on a single piece of paper, see Placing multiple title block borders on a layer.
To place a single title block border on a layer:
1.      Click the tool and mode.
2.      Do one of the following:
        To insert the title block border object with no rotation using a single click, click Single Point Insertion mode on the Tool bar.
        To insert the title block border object with a rotation set by the second click, click Standard Insertion mode on the Tool bar.
3.      Do one of the following:
        To use an existing title block border from the resource libraries, click Title Block Border Style on the Tool bar. From the Resource Selector, double-click a resource to activate it.
        To create a custom title block border, click Preferences. From the Title Block Border Preferences dialog box, select the style to use and/or set the basic drawing size default properties. For many standard drawing formats these properties are set by style (see Creating plug-in object styles).
4.      Click on the drawing to place the object. If Standard Insertion mode is used, click again to set the rotation.
A title block border object is placed on the drawing.
5.      Click Title block border settings from the Object Info palette to set additional parameters for the selected object.
Creating title block borders
Placing a title block border on multiple sheets
