Spotlight
preferences: Lighting devices: Class and color paneCommand |
Path |
Spotlight Preferences |
File > Document Settings |
The options on the Spotlight Preferences dialog box Lighting devices: Classes and color pane assign classes and specify attributes of the lighting devices in the file. The parameters selected can have a powerful global effect on all the devices, both existing and new.
Class and color assignments for lighting instruments allow the designer to:
● Assign the lighting instruments to a specific class, or to one or more classes determined by an instrument parameter.
● Control the color of lighting instruments, or parts of instruments, by gel color or from the Attributes palette.
● Control the wireframe light beams, angles, and centerline of lighting instruments by class.
● Control the label legend container appearance by class.
● Control the appearance and visibility of lighting instruments.
To assign classes and attributes for lighting devices:
1. Select the command.
2. The Spotlight Preferences dialog box opens. Click the Lighting devices: Classes and color pane.
Class setting changes require confirmation before regenerating the lighting devices.
Click
to show/hide the parameters.
