Access permissions are controlled by creating rules. These are sets of permitted products and borrowing times allowed, that apply to specific clients or groups of clients, or to computers. By default, all clients are granted access; rules set exceptions, but this setting can be reversed if needed.
To view and configure access permissions:
1. Select Access Permissions from the site protection System Menu.
The Access Permissions dialog box opens, listing permissions rules for groups of users. Rules are sets of allowed and/or reserved products that apply to specific users or computers.
Click
to show/hide the parameters.
2. Set up the permissions rules for groups of users by selecting Add Rule from the Rules menu at the top of the dialog box, or right-click in the rules area and select Add Rule from the context menu.
3. The Add/Edit Rule dialog box opens.
Click
4. “Users” can represent user names, computer names, or IP addresses. A group consists of a list of users. Define the needed rules for groups of users; for example, certain groups may only be permitted to use the Architect and Fundamentals products, while other users can only use Landmark and Fundamentals. If no products are selected, the users in the list cannot connect to the server at all. Licenses can also be reserved for groups of users. Each of these situations requires an individual rule for each group. Users in rules must be unique (the same user cannot have two different rules).
5. Click OK to return to the Access Permissions dialog box.
6. To edit an existing rule, select it and then select Edit Rule from the Rules menu at the top of the dialog box, or double-click on the rule, or right-click on the rule and select Edit Rule from the context menu.
7. To delete an existing rule, select it and then select Delete Rule from the Rules menu at the top of the dialog box, or right-click on the rule and select Delete Rule from the context menu.
8. Click OK to close the Access Permissions dialog box.
