Creating or editing saved views using the saved views menu
The View bar has shortcuts to save a view, to edit a saved view, or to switch the current drawing area view to a previously saved view.
Views can also be accessed through the Saved Views palette. Select Window > Script Palettes > Saved Views. Double-click the view name to switch to that view.
To use the Saved Views menu:
1.      Click the Saved Views menu from the View bar.
2.      Select the desired item from the menu.
Menu Item
Description
Save View
Opens the Save View dialog box
Edit View
Opens the Saved Views tab of the Organization dialog box
List of saved views
Select a saved view from the list to switch to that view
Creating saved views
Editing saved views
