Connect00012.pngAdding sockets
Device objects incorporate any number of input, output, or input/output (I/O) sockets. Since signals typically flow from left to right, place input sockets on the left side of a device and output sockets on the right. Sockets can be named based on the type of connector and the signal they carry, or by a custom naming convention. While sockets can be placed on the top side of a device, that area is normally reserved for the device name label.
Loop sockets loop to connect one socket to an adjacent socket on the same device (creating a “loop-thru”). The Terminator tool adds or removes a terminator on loop-thru outputs.
SocketL_tool.png Socket L
SocketR_tool.png Socket R
SocketT_tool.png Socket T
SocketB_tool.png Socket B
SocketL_Loop_tool.png Socket L Loop
SocketR_Loop_tool.png Socket R Loop
SocketT_Loop_tool.png Socket T Loop
SocketB_Loop_tool.png Socket B Loop
Terminator_tool.png Terminator
To add sockets to a selected device:
1.      Click the tool that matches the orientation for the socket from the Schematics tool set.
2.      Click to place the socket or loop-thru socket on the device.
The Socket Setup dialog box opens.
In addition to label information, the socket’s appearance indicates whether it is an output socket (red triangle), input socket (green triangle), or I/O socket (both red and green triangles). Socket appearance can be changed; see Editing devices and sockets.
3.      Add a Terminal to a socket if needed by clicking on the socket with the Terminator tool or by selecting Is Terminated from the Object Info palette of a selected socket. This type of socket cannot be connected with a circuit.
If you plan to reuse the device in the future, click Save as Symbol from the Object Info palette of the selected device to save the device as a symbol definition resource.
Connecting sockets
Placing devices
ConnectCAD
