Connect00065.pngCreating reports
The report commands in the ConnectCAD > Documentation menu create a variety of worksheets for labeling and reporting purposes.
The available commands depend on the worksheet resources in the ConnectCAD template file. Adding worksheets to the ConnectCAD.sta file in your user folder adds them to the menu, for easy access to customized worksheets.
Device reports list jackfield and terminal panels individually, with the number of holes used. This is helpful when trying to optimize patch-panel and term-panel layouts.
Command
Description
All Layers Cable Labels
Creates a worksheet listing circuit numbers and parameters from all layers
All Layers Cable Report
Creates a worksheet listing all circuit parameters from all layers
All Layers Device Report
Creates a worksheet listing devices and summarizing devices and parameters from all layers
Current Layer Cable Labels
Creates a worksheet listing circuit numbers and parameters from the current layer
Current Layer Cable Report
Creates a worksheet listing all circuit parameters from the current layer
Current Layer Device Report
Creates a worksheet listing devices and summarizing devices and parameters from the current layer
Rack Equipment Report
Creates a worksheet listing the equipment items and parameters from the file
Rack Frames Report
Creates a worksheet listing all of the rack frames and parameters from the file
Once a worksheet has been created, two-way worksheet editing is useful for updating the drawing from the worksheet; see Editar objetos de dibujo desde una hoja de cálculo.
Concepto: Generalidades de hojas de cálculo
ConnectCAD
