Connect00055.pngChecking the drawing
Command
Path
Check Drawing
        ConnectCAD > Drawing
        Document context menu
Vectorworks can automatically check the drawing (the current layer or all layers) for problems with sockets, circuits, devices, and signals.
To check the drawing:
1.      Select the command.
The Check Drawing dialog box opens.
2.      Select the drawing items to check and click OK.
When tracking down a problem, it’s helpful to avoid repeating tasks which passed successfully; deselect those.
3.      Drawing objects with problems are selected, and marked up with a special class to make them more visible. In some cases, additional drawing objects mark specific areas. Resolve the issues, clear the markup, and run the Check Drawing command again to verify.
Clearing drawing markup
Command
Path
Clear Markup
After running a drawing check (or the Compare Cable List and Drawing command) and resolving problem areas or determining that they are not an issue for the current schematic drawing, the highlighted markup can be removed.
To remove markup after a drawing check:
Select the command.
Comparing the cable list and the drawing circuits
Placing devices
Connecting sockets
ConnectCAD
