Connect00011.pngPlacing specialized devices
Specialized devices can be placed on the drawing, or placed “in line” on a circuit, dividing the circuit where they are placed. Terminal panels have a special socket that can accept connections from either side.
If an existing jack (jackfield) or terminal panel device is already selected when placing a new device, the new device is sequentially numbered.
VDA_tool.png VDA (video distribution amplifier)
ADA_tool.png ADA (audio distribution amplifier)
VideoJack_tool.png Video Jack (jackfield patch panel)
AudioJack_tool.png Audio Jack
DataJack_tool.png Data Jack
OpticalJack_tool.png Optical Jack
VideoJackU_tool.png Video Jack U-linked
AudioJackFull_tool.png Audio Jack Full-Normal
AudioJackHalf_tool.png Audio Jack Half-Normal
DataJackNormal_tool.png Data Jack Normal
OpticalJackLinked_tool.png Optical Jack Linked
VideoTermPanel_tool.png Video Term Panel
AudioTermPanel_tool.png Audio Term Panel
DataTermPanel_tool.png Data Term Panel
OpticalTermPanel_tool.png Optical Term Panel
ConnPanelInput_tool.png Conn Panel Input
ConnPanelOutput_tool.png Conn Panel Output
DINrailTerminal_tool.png DIN rail terminal
To place a specialized device:
1.      Click the tool that matches the type of required device from the Schematics tool set.
2.      For jack (jackfield) and panel tools, click the Preferences button on the Tool bar to open the Preferences dialog box. By default, the values from the ConnectCAD settings are applied (see Specifying ConnectCAD settings), but they can be overridden here.
3.      If placing the device over an existing circuit, the circuit is highlighted to indicate that the device will be inserted into the circuit. Click to place the device.
Depending on the tool type, one of the following dialog boxes opens automatically: VDA tool, ADA tool, Jackfield Setup, Term Panel Setup, or Connector Panel Setup. Specify the device parameters.
The Conn Panel Input and Conn Panel Output tools are special panel connector devices that can be associated with a Conn panel on the Rack Elevation layer. See Creating connector panel layouts.
4.      Specify the device parameters and labeling options, and click OK to place the device into the circuit or in the drawing.
If you continue placing the same jackfield or terminal panel device, the device number automatically increments.
Placing a basic or custom device
Building a device
Adding sockets
Editing devices and sockets
Placing devices
ConnectCAD
