Creating section-elevation lines
Tool
Tool set
Section-Elevation Line
Dims/Notes
The Section-Elevation Line tool creates an object that serves as a reference line graphic for vertical sections and elevations, or as a cutting plane graphic.
In Design Series products, section-elevation lines have additional functionality.
●       Create a section viewport from an unlinked section-elevation line.
●       Link a section-elevation line to an existing viewport, for annotation purposes.
●       Sync the line’s drawing title, drawing number, and sheet number with the linked viewport.
●       Automatically delete linked lines when a section viewport is deleted.
To create a section-elevation line:
1.      Click the tool.
2.Do one of the following:
●       Click Style on the Tool bar to select a resource from the Resource Selector.
●       Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
3.Click to place one end of the section-elevation line. To insert a multi-segment line, click again to define each segment. Double-click at the end point to finish the section-elevation line.
Editing section-elevation lines
Once a section-elevation line is in the drawing, you can use the Selection or Reshape tool to edit the shape of the line object.
The following additional options are available on the Object Info palette when editing section-elevation lines.
Option
Description
Style list options
●       Replace: Applies a different style to this object
●       Convert to Unstyled: Allows you to modify the settings and marker layout for this object only
●       Edit Style: Allows you to modify the settings and marker layout for all objects in the drawing that use the current style
See Creating styles for markers and drawing labels for details.
Create Section Viewport
(Design Series required)
For a marker that is not already linked to a viewport, opens a dialog box to create a vertical section viewport (see Creating a vertical section viewport)
Navigate to Viewport
For a marker that is linked to a viewport, navigates to the viewport
Reverse Direction
Reverses the marker arrow direction; for a section viewport that is defined by the line, also reverses the view when objects beyond the section plane are visible
Edit Marker Layout
(unstyled markers)
Opens an editing window to change the geometry and text in the marker; see Creating styles for markers and drawing labels
Use different end marker
If the line Configuration is set to Section, specifies that the marker defined in the end marker layout will be used for one end of the section-elevation line
Edit End Marker Layout
If Use different end marker is selected, opens an editing window to create or edit a marker for the end of the section-elevation line; see Creating styles for markers and drawing labels
