Setting global visibility with class and design layer options
Command
Path
●       Class Options
●       Layer Options
●       View
●       Document context menu
The Class Options and Layer Options commands control how all the inactive classes or design layers in a drawing display. For example, a drawing project can be set to display only the active class, temporarily hiding all objects assigned to other classes. When you make a different class active, the objects in the new active class display, and all other objects are hidden. This makes it easier to display, snap to, and edit objects in the current class or design layer.
These commands establish the maximum allowed visibility settings for the inactive classes and layers. Individual inactive classes and layers can be set to lower visibility (made invisible or grayed) using the Visibility columns or The Visibility tool, but if class/layer options are set to Active Only or to one of the gray settings, inactive classes/layers cannot be displayed with normal visibility (see Concept: Visibility of drawing elements).
Objects that are in both the active class and the active layer always display with normal visibility.
To change the class or layer visibility options:
1.      Select the command and then the option.
Command
Description
Shortcut
Active Only
Displays only objects in the active class/layer; only the active class/layer prints
●       Ctrl+Shift+Alt+3 (classes, Windows)
●       Cmd+Shift+Option+3 (classes, Mac)
●       Ctrl+Alt+3 (layers, Windows)
●       Cmd+Option+3 (layers, Mac)
Gray Others
Displays the active class/layer normally and all other classes/layers are grayed (except for those set to invisible); even though visible, objects in grayed classes/layers cannot be edited
●       Ctrl+Shift+Alt+4 (classes, Windows)
●       Cmd+Shift+Option+4 (classes, Mac)
●       Ctrl+Alt+4 (layers, Windows)
●       Cmd+Option+4 (layers, Mac)
Gray/Snap Others
Displays the active class/layer normally and all other classes/layers are grayed (except for those set to invisible); objects in any normally displayed or gray class/layer can be snapped to. Only objects in the active class/layer can be edited.
●       Ctrl+Shift+Alt+5 (classes, Windows)
●       Cmd+Shift+Option+5 (classes, Mac)
●       Ctrl+Alt+5 (layers, Windows)
●       Cmd+Option+5 (layers, Mac)
Show Others
All classes/layers display normally, except for those set to invisible or grayed; even though visible, objects in classes/layers other than the active class/layer are not editable and cannot be snapped to
●       Ctrl+Shift+Alt+6 (classes, Windows)
●       Cmd+Shift+Option+6 (classes, Mac)
●       Ctrl+Alt+6 (layers, Windows)
●       Cmd+Option+6 (layers, Mac)
Show/Snap Others
All classes/layers display normally, except for those set to invisible or grayed; objects in any normally displayed or gray class/layer can be snapped to. Only objects in the active class/layer can be edited.
●       Ctrl+Shift+Alt+7 (classes, Windows)
●       Cmd+Shift+Option+7 (classes, Mac)
●       Ctrl+Alt+7 (layers, Windows)
●       Cmd+Option+7 (layers, Mac)
Show/Snap/Modify Others
All classes/layers display normally, except for those set to invisible or grayed. Objects in any normally displayed or gray class/layer can be snapped to; only objects in normally displayed classes/layers can be edited. (An object on another layer can only be edited if its layer scale and view are the same as those of the active layer.) Locked objects display with gray highlighting.
●       Ctrl+Shift+Alt+8 (classes, Windows)
●       Cmd+Shift+Option+8 (classes, Mac)
●       Ctrl+Alt+8 (layers, Windows)
●       Cmd+Option+8 (layers, Mac)
2.The current class or design layer visibility changes accordingly.
