Modifying trusses and systemsThe truss context menu provides options for selecting and editing truss objects or entire systems. Right-click on a truss object in the drawing, and select the desired command from the context menu. Many of these commands are also available on the Object Info palette.
Click
to show/hide the parameters.
Custom shortcuts can be assigned to the commands; see Modifying menus and commands.
