Spot.pngPlacing a video camera
Tool
Tool set
Video Camera
●       Event Design
●       Visualization
For use by event designers, the Vectorworks Spotlight video camera object includes a variety of lenses, camera bodies, and stand types, to mimic real-world video camera options. The video camera’s active view displays a view similar to a real video camera using the same lens, camera body, and stand type as in the actual event space. The active view updates live as settings change, so designers can plan the lighting and shots needed for the production.
To insert a video camera:
1.      Click the tool.
2.Do one of the following:
●       Click Lens, Body, and/or Stand on the Tool bar to select resources from the Resource Selector.
●       Click Preferences to open the Object Properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
3.Click to place the object, and click again to set the rotation.
Activating a video camera
Linking a camera view to a sheet layer viewport
