Connecting sockets|
Tool |
Tool set |
Connect
Schematics |
The Connect tool draws circuit connections between sockets. Circuits follow a logical flow from output to input. Once a circuit connects two device sockets, it maintains the connection between those sockets. If the devices move, the circuits refresh.
Mode |
Description |
Single Connect |
Connects an output/IO socket to an input/IO socket |
Multi Connect |
Connects multiple output/IO sockets to input/IO sockets with the same signal |
Polyline |
Draws the circuit similar to a polyline with corner vertices; click while drawing to create vertices, routing the circuit around other drawing objects as needed. See Creating polylines. |
Rounded |
Draws the circuit with rounded vertices (generally used to denote busses or multi circuits) |
Chamfer |
Draws the circuit with chamfered vertices |
Arrow |
Draws the circuit with arrows; on the output socket, the arrow indicates the direction of signal flow; the destination input socket displays a “reverse arrow.” This is useful when a polyline circuit would be too complex or would cross over too many lines, or to connect devices on different layers, including with project sharing (see Project sharing). When a file with arrow circuits is exported to a single, multi-page PDF with the Publish command (Design Series required), hyperlinks are automatically created to connect the sockets. This allows you to navigate through the circuit by clicking on the arrow circuit. |
Links |
Draws a circuit that connects devices in two different Vectorworks files; see Connecting devices in different files. However, use of this mode is discouraged, since it will be deprecated in the future. Instead, create a single shared project file with separate layers for each subsystem, and use the Arrow mode to connect devices between layers in the file (see Project sharing). |
