Connect00003.pngSpecifying ConnectCAD settings
Command
Path
ConnectCAD Settings
ConnectCAD
Prior to beginning the schematic design, set up the default ConnectCAD settings. The settings apply to the current file.
To specify the ConnectCAD settings:
1.      Select the command.
The ConnectCAD Settings dialog box opens.
2.Click the General Settings tab to set global default parameters.
3.Click the Panel Settings tab to set up the jackfield and terminal panel parameter defaults. These settings override any existing custom labels.
4.Click the Numbering tab. Select a standard numbering system to use, or add a custom system. See Cable numbering rules for more information about numbering rules.
Customizing options
Advanced users can customize default items such as cable lengths, signal types, and connector types. The selections available from ConnectCAD come from simple tab-delimited text files located in the Plug-Ins/connectCAD_Data folder within the application folder.
●       To create custom files for yourself, copy the files to your user folder and edit them: [User]/Plug-ins/connectCAD_Data
●       To share custom files with coworkers, place them in a workgroup folder: [Workgroup]/Plug-ins/connectCAD_Data
Edit the files to suit company standards or add more options. The first row is a header that describes the function of each column; additional rows with custom options can easily be added, edited, or deleted using a text editor application.
File name
Purpose
ADAdata.txt
Device data for audio DA objects
CableLengths.txt
Standard cable lengths available in Cable Length list of the Object Info palette for circuits
ConnectorTypes.txt
Connector types
JFdata.txt
Physical size and label pitch for jackfields
SignalTypes.txt
Signal types
TPdata.txt
Physical size and label pitch for terminal panels
VDAdata.txt
Device data for video DA objects
Vectorworks preferences: User Folders pane
