 Data mapping expressions
Data mapping expressionsEach formula consists of one or more expressions from the following list. The expressions are described in more detail in the rest of this section.
| Expression | Description |
| Constants | Types of data, such as integers, Boolean constants, numbers, and text constants |
| Fixed values | Text strings, numerical and logical values, and so on |
| Operators | Addition, subtraction, comparison, and so on |
| Variables | Vectorworks data sources, such as object parameters, style information, class name |
| Functions | Mathematical functions, string manipulations, conditional functions, and more |
| ELSE | Method of adding alternative data mapping, if the previous one yields an empty value |
| Constant | Description | Examples |
| Boolean | Values are used for Boolean parameters, and are either true or false, written as string constants enclosed within apostrophes | ‘FALSE’ ‘TRUE’ |
| Integer | Positive or negative numbers and 0, written as numbers with no decimal point or apostrophes | 4 125 |
| Rational number | Real number values, written as a number with a decimal point and no apostrophes | 3.14 -12.0 248.141539 |
| Text | String values enclosed within apostrophes | ‘Unstyled Wall’ ‘INTERNAL’ ‘NOTDEFINED’ |
| Operator | Description |
| + | Unary Plus |
| - | Unary Minus |
| + | Binary Plus, Addition, Concatenation |
| - | Binary Minus, Subtraction |
| * | Multiplication |
| / | Division |
| = | Logical EQUALS |
| ! | Logical NOT |
| | | Logical OR |
| & | Logical AND |
| != | Logical NOT EQUAL |
| > | Greater than |
| < | Less than |
| >= | Greater than or equal |
| <= | Less than or equal |
Variables represent sources of data from Vectorworks. They can be combined with constants, function results, and other variables by using operators. The variable type (name) is the same as that of the data source type. Variables are enclosed by square brackets, since spaces are permitted in the name.
| Variable | Format | Example |
| Parameters from an object | [Object.NameOfTheParameter] If the parameter is a pop-up field, the variable returns the localized value. If you need the universal value instead, add an asterisk after the name of the field. | [Object.Config] [Object.Column ID] [Object.Struct Type] [Object.structuralUse*] |
| Vectorworks name | [Object.VW_Name] | [Object.VW_Name] |
| Record field data from a record format | [Record.NameOfTheRecord.NameOfTheField] If a record by that name is not attached to the object, then the default value of the record field is taken as the value of the variable. | [Record.MyRecord.Price] [Record.Plant Record.Latin Name] |
| Data from style | [Style.NameOfTheField] Currently supported data fields are: Name (the name of the style), Mark, Function, Description, Exterior (Boolean), Load-Bearing (Boolean), Fire Rating, Combustible Construction (Boolean), Compartmentation (Boolean), U-Value, Acoustic Rating, Cost Index System, Cost Index Code, Model, Manufacturer. | [Style.Function] [Style.Name] [Style.Fire Rating] |
| Component | [Component.NameOfTheField] Currently supported data fields are: Name (the name of the component), Function, Class, Thickness, Lambda, U-Value. When the “export by components” option is not used, these variables correspond to the core component. | [Component.Function] [Component.Thickness] |
| Material | [Material.NameOfTheField] Currently supported data fields are: Name, Description, Mark, Keynote, IsVolumetric, Category, Standard,  ReferenceID, ClassificationDescription, Manufacturer, ProductModel, ProductName, ProductDescription, ProductURL, ProductSource, ProductFinish, ProductCost,  | [Material.Mark] [Material.Category] [Material.Lambda] |
| Field data from a record attached to a material | [Material Record.NameOfTheField] | [Material Record.CastInPlace] [Material Record.TimeToDry] |
| Class name | [ClassName] | [ClassName] |
| Layer name | [LayerName] | [LayerName] |
| Story name | [StoryName] | [StoryName] |
| Function | Description |
| PI ( ) | Returns the number Π |
| SIN (radians) | Returns the sine |
| COS (radians) | Returns the cosine |
| ABS (number) | Returns the absolute value |
| SQRT (number) | Returns the square root |
| INT (number) | Returns the converted integer value |
| REAL (number) | Returns the converted real value |
| IF (logical_expression, value_expression1, value_expression2) | Calculates logical_expression and returns the calculated value of value_expression1, if TRUE, or value of the value_expression2, otherwise |
| SELECT1 (number_expression, value_expression1, value_expression2, …, value_expressionN) | Calculates number_expression and returns the calculated value of value_expression1, if the result is 0, value of the value_expression2, if the result is 1 and so on. Returns the value of the last expression, if the result is bigger than N-1. The number of the function parameters must be 3 or more. |
| SELECT2 (logical_expression1, value_expression1, logical_expression2, value_expression2, …, logical_expressionN, value_expressionN) | Calculates the first logical expression and returns the calculated value of value_expression1, if the result is TRUE; otherwise, continues with the next logical expression and value expression pair. The number of the function parameters must be even, and greater than 2. |
| COUNTER (“name”) | Returns auto-incremented values (for generating unique values) |
| BOUNDS (“name”) | Returns X-, Y-, Z-, or Width/Height/Depth dimensions of an object |
| LEFT (text, count) | Returns the left side of the string, using the specified count of characters. Returns an empty string if the count value is incorrect. |
| RIGHT (text, count) | Returns the right side of the string, using the specified count of characters. Returns an empty string if the count value is incorrect. |
| MID (text, index, count) | Returns the right side of the string, split by the position index (0 is the position of the first character) and using the specified count of characters. Returns an empty string if the index or count values are incorrect. |
| FIND (subtext, text) | Returns the zero-based position of subtext in text, if found, or -1 if not found. Example: example FIND (‘fo’, ‘foo’) returns 0 and FIND (‘oo’, ‘foo’) returns 1. |
| LEN (string) | Returns the length of the string |
| INSERT (string1, index, string2) | Inserts string2 in string1 at the given position index |
| DELETE (string, index, count) | Removes the right side of the string, split by position index and having the specified count of characters |
| REPLACE (string1, string2, string3) | In string1, replaces all occurrences of string2 with string3 |
| TRIMLEFT (string) | Returns the left trimmed string from whitespaces |
| TRIMRIGHT (string) | Returns the right trimmed string from whitespaces |
| MAKEUPPER (string) | Returns the uppercase string |
| MAKELOWER (string) | Returns the lowercase string |
| GETCOMPONENTINFO (index, selector) | Returns information about the selected component (wall/slab), where index is the number of the component, and selector is one of the following: 1 (component name) 2 (component function) 3 (component class) 4 (component thickness) |
| ISFLIPPED( ) | Returns whether the object is mirrored or not |
| GETOBJECTVARIABLE(selector)
 | Returns the value of a Vectorworks object property. For specific object selector values, please see Appendix G from the VectorScript Function Reference. developer.vectorworks.net/index.php/VS:Function_Reference_Appendix#appx_g. |
