Bolts and
nutsMode |
Tool |
Tool set |
Modes for Creating lines |
Bolt and Nut (mm or inch)
Detailing |
To insert a bolt and nut (mm or inch):
1. Click the tool and mode.
2.Click to place the object, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Click
to show/hide the parameters.
